Temperature on a cable
Posted 16 feb 2017, 08:18 GMT-5 Electromagnetic Heating, Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.2 5 Replies
I am trying to verify the temperature on three cables representing a transmission line due to the heating caused by the current passing through them, but the temperature shown in the Results is uniform on the cables, even though the current in one of them is significantly greater. The geometry consists only of three parallel aluminium cilinders.
I have specified the Ground node to one end of each cable and assigned an External Current Density to them, (I have also tried assigning Normal Current Density to the opposite end of the cable) and also assigned a convective heat flux on the cable domains with the aluminium heat tranfer coefficient.
I was following the electric heating on a busbar tutorial as I am new to COMSOL.
The idea is then compare the temperature of the same cables but with a layer of a non-conductive material around one of them.
Is it not possible to verify the Joule Heating using a current density? Do I need a box of air around the cables?
Thank you in advance for any help
5 Replies Last Post 6 mar 2017, 09:09 GMT-5
