Exporting surface displacement
Posted 3 feb 2011, 08:26 GMT-5 Geometry, Results & Visualization 2 Replies
Hey there,
I messured some eigenfrequencies of a thin plate with Comsol 3.5. Now I'd like to calculate the wave vector with a different software. Therefore I need the displacement of the plate in equidistant coordinates or pixels. But because of the mesh Comsol uses, the distances between the meassured points differ, depending on where you are on the plate. Is there a way to export a file that includes the interpolated values (for example the z displacement of the plate for a coordinate system with 300 equidistant points in x and 400 points in y direction)? I know that it's possible to make a Cross-Section-Plot which gives me the interpolated data for a specific line (for example with a Line-Resulution of 400). If there is a way to do this step 300 times in a row with different x values and export this data, my problem would be solved too :-)
Thanks for your help!!!
Stephan
Stephan
2 Replies Last Post 3 feb 2011, 11:39 GMT-5
