Apply a dynamic load to a truss bridge
Long Story Short:
I am currently conducting a project where I analyze a dynamic load on a bridge that simulates a boat colliding with the side of the span of the bridge. Is there any way to apply a dynamic point or face load on the model trusses that are provided with the COMSOL software ( the Pratt Truss Tutorial) or would I need to build a completely different model in COMSOL to achieve this type of loading? Anyone know???
Ryan
3 Replies Last Post 9 feb 2011, 01:51 GMT-5
Posted: 1 decade ago 3 feb 2011, 16:56 GMT-5
for me trusses have only lines/edges and points, so you can mainly apply point loads. Then to get the point load to change with time, it's essentailly done by generating a function (your impulse shape, smooth enought to be derived at least once, if possible twice), and depending on the time; then off you go
What else so you need ?
Hi for me trusses have only lines/edges and points, so you can mainly apply point loads. Then to get the point load to change with time, it's essentailly done by generating a function (your impulse shape, smooth enought to be derived at least once, if possible twice), and depending on the time; then off you go What else so you need ? -- Good luck Ivar
Posted: 1 decade ago 8 feb 2011, 19:07 GMT-5
Ivar,
Thanks for your help. Is applying the dynamic load as simple as inputting a function for a point/face load as opposed to a numerical value? If not, do you know where I could find any tutorials or instructions on how to apply this load(I'm a novice COMSOL user)?
Ryan
Ivar, Thanks for your help. Is applying the dynamic load as simple as inputting a function for a point/face load as opposed to a numerical value? If not, do you know where I could find any tutorials or instructions on how to apply this load(I'm a novice COMSOL user)? Thanks, Ryan
Posted: 1 decade ago 9 feb 2011, 01:51 GMT-5
the best way, and the one I followed was to do the exercices in the doc, run the video's on the web AND then follow a few of the COMSOL 1 day courses, these are really usefull toget a cick start
Hi the best way, and the one I followed was to do the exercices in the doc, run the video's on the web AND then follow a few of the COMSOL 1 day courses, these are really usefull toget a cick start -- Good luck Ivar
