Designing a cantilever with narrow strip at the hinged part
sir,
may i know how to design a cantilever in 3.5a and 4.1 comsol versions for the given structure.
2 Replies Last Post 6 feb 2011, 00:15 GMT-5
Posted: 1 decade ago 5 feb 2011, 03:57 GMT-5
all depends how and what you want to study.
you can start in 2D draw 2 or 3 rectangles side by side, define the "thickness" depth in "Z" direction (out of paper) , define the material properties and then go on.
You can also consider the large block as rigid and just not inlude it at all (depends on the details you are looking for)
Then in 3D you draw 3 blocks, side by side
To learn how to use the CAD section perform some of the exercices that are described in detail in the doc
There is basically no differences (apart from the GUIs) between 3.5 and 4 for the geoemtry build up
Hi all depends how and what you want to study. you can start in 2D draw 2 or 3 rectangles side by side, define the "thickness" depth in "Z" direction (out of paper) , define the material properties and then go on. You can also consider the large block as rigid and just not inlude it at all (depends on the details you are looking for) Then in 3D you draw 3 blocks, side by side To learn how to use the CAD section perform some of the exercices that are described in detail in the doc There is basically no differences (apart from the GUIs) between 3.5 and 4 for the geoemtry build up -- Good luck Ivar
Posted: 1 decade ago 6 feb 2011, 00:15 GMT-5
Thank you for your help
