Re: Moving Boundaries Problem (ALE) / Inverted Mesh Warnings
Posted 5 feb 2011, 04:31 GMT-5 3 Replies
I am working on a 1-D moving boundaries problem using ALE application mode. In this model, two boundaries are moving on one side with different velocities.
Let me explain clearly with number. Consider 3 boundaries, where the first boundary is fixed. Second and third boundaries are moving towards the first. Here, the third boundary is moving with a higher velocity than the second one. So, I set up a if condition such that it can use it's own velocity until it hits the second boundary and then the third boundary must use the velocity of the second one. So that both boundaries move together.
When i tried to model the above mentioned problem, I got inverted mesh warnings. I have tried several things...for example, allowing a definite (small) distance between the second boundary and the third one. so that i can get rid of inverted mesh warnings. but unsucessful.
Can i build a model in COMSOL where two domains collapse into one after a certain time?
Any suggestions/comments are greatly appreciated.
Thank you,
Manohar
Thank you,
Manohar
3 Replies Last Post 5 feb 2011, 06:47 GMT-5
