Eddy current simulation not converging when velocity increases
Posted 15 mar 2017, 17:34 GMT-4 Low-Frequency Electromagnetics, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.2a 2 Replies
My simulation simulates an array of magnets moving over an aluminum plate at a fixed height and a given velocity, and while it computes and yields results similar to those of a numerical analysis, it won't compute at high velocities--which in this case refers to speeds greater than 50 m/s; I need to be able to simulate the system up to 115 m/s, so this is a big issue.
When I say that the simulation doesn't converge, I don't mean that I get a non-convergence error, I mean that the computation time approaches infinity and the convergence plot levels out and won't decrease any further. since skin depth becomes a more significant factor at higher velocity I've tried to make the mesh size a function of the velocity so that the mesh elements will always be smaller than the skin depth so that it can be resolved, however the number of mesh elements gets so large that the computation time is still excessively long, and since I'm using a parametric sweep the computation time becomes even longer.
I'm wondering if there are any meshing methods or techniques to make this work/work faster; this is under the assumption that the only source of this issue is that at high velocity the skin depth becomes smaller than the minimum element size and thus can't be resolved and COMSOL can't compute a solution, hopefully there isn't anything else wrong with the model that I haven't caught yet.
Does anyone have any insight into this type of simulation and can help me out with this issue? The file is too large to attach to this post (6.31 MB) but I can email it to anyone who's willing to take a look at it.
2 Replies Last Post 15 mar 2017, 19:25 GMT-4
