Failed to evaluate variable Jacobian. - Variable: mat.nu ,Geometry: 1, Domain: 1
Hello everyone,
I am new in comsol. I am using comsol V4.0a.
I am trying to simulate of electromagnetic force problem.
But I am having the following prob.
Variable: mat.nu ,
I cant find out the error.Please help me.
Ayan
2 Replies Last Post 7 mar 2011, 12:50 GMT-5
Posted: 1 decade ago 8 feb 2011, 06:24 GMT-5
you try to calculate your mechanical problem also in the air domain. Then there are missing material parameters, e.g. Poisson ratio for air. If you want to calculate mechanical behaviour in the metal domains just deselect the air from the "solid mechanics" tab.
Hi you try to calculate your mechanical problem also in the air domain. Then there are missing material parameters, e.g. Poisson ratio for air. If you want to calculate mechanical behaviour in the metal domains just deselect the air from the "solid mechanics" tab.
Posted: 1 decade ago 7 mar 2011, 12:50 GMT-5
I have same prob with my model ( V 4.1 a )
as you said I removed air from domain but still have same porb.
would you please check it for me?
I have same prob with my model ( V 4.1 a ) as you said I removed air from domain but still have same porb. would you please check it for me?
