Out of memory during out-of-core LU factorization
I have a CFD model with 1056,2892 degrees of freedom and a server with 128GB memory. I assume this memory size is enough for computing the matrix I have now. But I keep getting a error:
Failed to find a solution.
Segregated Step 1
Out of memory during out-of-core LU factorization.
In Segregated Step 1:
Even after I checked "out-of-core", it still returns me this error.
Any one has some advice for this please?
Thank you so much!
Chang
1 Reply Last Post 21 mar 2017, 11:32 CET
Posted: 8 years ago 21 mar 2017, 11:32 CET
to my experience "Out of memory" means not the disk memory, but the working memory.
If the disk memory is meant, it is really written "Out of disk memory".
I had both problems and solved it by extending the working memory from 16GB to 32GB and a new hard-drive.
With the new hardware it worked for me.
Or you have to simplify your model. In my case the memory was enough as long as I jused electric potential in my model. Changing this to floating potential, I got the same error message as you. When I got the new working memory the computer managed to solve also the configuration with the floating potential.
Hope this helps you somehow.
Cheers,
Saskia
Hi, to my experience "Out of memory" means not the disk memory, but the working memory. If the disk memory is meant, it is really written "Out of disk memory". I had both problems and solved it by extending the working memory from 16GB to 32GB and a new hard-drive. With the new hardware it worked for me. Or you have to simplify your model. In my case the memory was enough as long as I jused electric potential in my model. Changing this to floating potential, I got the same error message as you. When I got the new working memory the computer managed to solve also the configuration with the floating potential. Hope this helps you somehow. Cheers, Saskia
