Surface Plot for a Time Dependent ODE
I have computed the result for a time dependent ODE. The dependent variable is u. I would like to plot a surface graph, u=f(x,t). Is it possible to do this within the GUI? Thanks in advanced.
1 Reply Last Post 9 feb 2011, 05:27 GMT-5
Posted: 1 decade ago 9 feb 2011, 05:27 GMT-5
I assume you have a 1D or 2D depdendet variables with at least "x" then, yes I would use the "results - Derived Values to fill in a Table, and then plot that
Hi I assume you have a 1D or 2D depdendet variables with at least "x" then, yes I would use the "results - Derived Values to fill in a Table, and then plot that -- Good luck Ivar
