AFM
Hi everyone,
I´m Giulio. Currently I´m involved in an University project regarding the modelling of AFM (Atomic Force Microscopy). Is anyone here that treats the same matter? Maybe we can keep in touch and confront each other...
Thank You
Giulio
1 Reply Last Post 8 mag 2011, 12:52 GMT-4
Hello Giulio Ferrazzi
Posted: 1 decade ago 8 mag 2011, 12:52 GMT-4
Hi there,
Im modelling the damping mechanisms of AFM cantilevers using comsol 4.1. Basically it is heat dissipation from the material, fluid damping from the environment and coupling effects with the support.
I've been using the structural mechanics module, heat module, pressure accoustics module for frequency analysis and eigenfrquency analysis.
Hi there, Im modelling the damping mechanisms of AFM cantilevers using comsol 4.1. Basically it is heat dissipation from the material, fluid damping from the environment and coupling effects with the support. I've been using the structural mechanics module, heat module, pressure accoustics module for frequency analysis and eigenfrquency analysis.
Suggested Content
