Livelink with matlab, exporting custom expression
I'm using livelink with Matlab to create a simulator of dielectrophoresis force. I need to export an expression like this one: d(es.normE*es.normE,x). How can i do this?
I succeed in exporting es.normE thanks to mpheval() but i got a syntax error when using the aforementioned expression.
Thanks for your helps
Vladimir
5 Replies Last Post 19 mag 2017, 04:11 GMT-4
Posted: 7 years ago 28 apr 2017, 11:34 GMT-4
Hi Vladimir
It works for me.
What version of Comsol are you using?
What is the exact error message?
Lars Gregersen
Comsol Denmark
Hi Vladimir It works for me. What version of Comsol are you using? What is the exact error message? -- Lars Gregersen Comsol Denmark
Posted: 7 years ago 29 apr 2017, 09:27 GMT-4
Updated: 7 years ago 29 apr 2017, 09:27 GMT-4
Hi Lars,
I'm using COMSOL 5.2 (version: 220).
Here is the code:
pd=mpheval(model,'d(es.normE*es.normE,x) d(es.normE*es.normE,y)','selection','pointi');
Here is the message:
Error using mpheval (line 328)
mpheval (174): Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Syntax error in expression
(rethrown as com.comsol.util.exceptions.FlException)
Erreur de syntaxe dans une expression.
- Expression: d(es.normE*es.normE,x) d(es.normE*es.normE,y)
- Sous-expression: d(es.normE*
- Position: 2
Vladimir
Hi Lars, I'm using COMSOL 5.2 (version: 220). Here is the code: pd=mpheval(model,'d(es.normE*es.normE,x) d(es.normE*es.normE,y)','selection','pointi'); Here is the message: Error using mpheval (line 328) mpheval (174): Java exception occurred: Exception: com.comsol.util.exceptions.FlException: Syntax error in expression (rethrown as com.comsol.util.exceptions.FlException) (rethrown as com.comsol.util.exceptions.FlException) Messages: Syntax error in expression Syntax error in expression Erreur de syntaxe dans une expression. - Expression: d(es.normE*es.normE,x) d(es.normE*es.normE,y) - Sous-expression: d(es.normE* - Position: 2 Vladimir
Posted: 7 years ago 2 mag 2017, 03:15 GMT-4
You are doing it wrong ;-)
If you wish to evaluate more than one expression you should put them in a cell array:
pd=mpheval(model, {'d(es.normE*es.normE,x)' 'd(es.normE*es.normE,y)'}, 'selection', 'pointi');
Lars Gregersen
Comsol Denmark
Hi You are doing it wrong ;-) If you wish to evaluate more than one expression you should put them in a cell array: pd=mpheval(model, {'d(es.normE*es.normE,x)' 'd(es.normE*es.normE,y)'}, 'selection', 'pointi'); -- Lars Gregersen Comsol Denmark
Posted: 7 years ago 2 mag 2017, 05:15 GMT-4
Ok, i'm confused because this command works well:
pd=mpheval(model,'V es.normE es.Ex es.Ey','selection','pointi');
I have another question. When i evaluate with pointi defined as follow:
model.selection.create('pointi','Ball');
model.selection('pointi').set('posx','L/2');
model.selection('pointi').set('r','8');
model.selection('pointi').set('entitydim',0);
model.selection('pointi').set('condition','inside');
this select only, if any, the geometrical point inside the Ball.
If i want to create a selection on all the mesh node inside pointi, should i create firstly a geometrical domain according to pointi ?
Hi, Ok, i'm confused because this command works well: pd=mpheval(model,'V es.normE es.Ex es.Ey','selection','pointi'); I have another question. When i evaluate with pointi defined as follow: model.selection.create('pointi','Ball'); model.selection('pointi').set('posx','L/2'); model.selection('pointi').set('r','8'); model.selection('pointi').set('entitydim',0); model.selection('pointi').set('condition','inside'); this select only, if any, the geometrical point inside the Ball. If i want to create a selection on all the mesh node inside pointi, should i create firstly a geometrical domain according to pointi ?
Posted: 7 years ago 19 mag 2017, 04:11 GMT-4
Hi Vladimir
Yes, this is a feature, but this feature only works with simple expressions and not when you are using functions with multiple parameters.
Selections work on the geometry level. Why do you need a selection of the interior mesh points?
Lars Gregersen
Comsol Denmark
Hi Vladimir [QUOTE] Ok, i'm confused because this command works well: pd=mpheval(model,'V es.normE es.Ex es.Ey','selection','pointi'); [/QUOTE] Yes, this is a feature, but this feature only works with simple expressions and not when you are using functions with multiple parameters. Selections work on the geometry level. Why do you need a selection of the interior mesh points? -- Lars Gregersen Comsol Denmark
