7 years ago
15 mag 2017, 16:39 GMT-4
Check the installation guide (pdf) and the COMSOL reference manual under "COMSOL commands".
But I would recommend to check first with your net/sysadmin, as it's not always "just" to open a port and use "any" port on the net.
And depending on the licence you have it might not be compatible
7 years ago
16 mag 2017, 02:52 GMT-4
Hi Ivar,
thanks for your reply. I searched through the manual before but I didn't find any helpful information yet. There are many descriptions for setting up the COMSOL Server App which I don't use though.
I'm going to have a talk with one of our university's network's admin so I will see that I can do about that problem.
Sincerely,
Philipp.
Hi Ivar,
Sincerely,
Philipp.
Magnus Ringh
COMSOL Employee
7 years ago
16 mag 2017, 05:17 GMT-4
This information is available in the COMSOL Multiphysics Reference Manual, in the Running COMSOL Multiphysics chapter, under COMSOL Multiphysics Server Commands. You can use the option -port <port>, where <port> is the port number, to specify a TCP/IP port to listen for attempts to connect.
Magnus Ringh, COMSOL
This information is available in the COMSOL Multiphysics Reference Manual, in the Running COMSOL Multiphysics chapter, under COMSOL Multiphysics Server Commands. You can use the option -port , where is the port number, to specify a TCP/IP port to listen for attempts to connect.
7 years ago
16 mag 2017, 06:25 GMT-4
Thanks alot,
that certainly will do :)
Thanks alot,
7 years ago
16 mag 2017, 07:23 GMT-4
Thanks alot,
I just found the actual problem... It's not the ports blocking COMSOL. I guess I'm just doing someting wrong. The "Server" runs the program comsolmphserver.exe which I need the Comsol Multiphysics Client to couple with. However, I used the Comsol Client, which apparently isn't the same.
My initial intention was to only install the GUI (the client) on my personal pc and keep the actual Comsol Multiphysics program and license on the academic pc I'm working with. Is that possible? I had difficulties installing Comsol on my own pc, for I didn't know which boxes to uncheck in that case.
Could someone help me out?
Thanks alot,
Philipp.
[QUOTE]
Thanks alot,
[/QUOTE]
Thanks alot,
Philipp.
