Dave Greve
Certified Consultant
7 years ago
31 mag 2017, 17:17 GMT-4
> I wanted to set 1W radiated power for the lumped port, so i chose 10V and 50ohm as the input for lumped port setting section
You will only radiate 1 W if the antenna input impedance is 50 ohms. Perhaps it is not.
Also- what boundary condition are you using for the surrounding domain?
D W Greve
DWGreve Consulting
D W Greve
DWGreve Consulting
7 years ago
31 mag 2017, 23:10 GMT-4
Thankyou for your response,
I used perfect electric conductor boundary condition on 2 patches of the antenna and between them i used a lumped port. so basically on mobile phone i have used only 2 boundary conditions, lumped port and perfect electric conductor.
Dave Greve
7 years ago
1 giu 2017, 10:52 GMT-4
That's not what I was asking.
To do a calculation you need to surround the antenna and object with a domain (presumably air). There needs to be a boundary condition on the surface of that domain. Usually we use either the scattering boundary condition or a far-field domain to approximate an infinite region. In either case any power radiated but not absorbed by the object is radiated to "infinity."
If you made the surface of the air domain a perfect conductor, then there is no power lost at the boundaries. THEN I would investigate the input impedance of your antenna, which will be affected by the surrounding environment. Evaluate the impedance under Derived values > Global evaluation. You can look at Z11 or S11.
D W Greve
D W Greve
7 years ago
1 giu 2017, 12:25 GMT-4
Hello sir,
sorry for the confusion, yes i did choose air from the material section and set it around the antenna, i have also created a perfectly matched layers around my whole model and set the scattering boundary on the boundaries of perfectly matched layers.
Please tell me what would i be doing wrong?
Thanks.
Hello sir,
Thanks.
7 years ago
1 giu 2017, 23:10 GMT-4
I choose global evaluation, then in the expression setting i select "emw.S11" and evaluate it. I got 0.032260+0.94213i in the table below graphics window. What does this number means?
Thanks.
Thanks.
Dave Greve
7 years ago
2 giu 2017, 10:55 GMT-4
Updated:
7 years ago
2 giu 2017, 10:56 GMT-4
S11 is the ratio between the reflected wave and the incident wave phasors.
Your S11 has a magnitude close to unity and therefore indicates that almost all of the incident energy is reflected. Your antenna is not well matched to 50 ohms.
DW Greve
DW Greve
7 years ago
2 giu 2017, 12:19 GMT-4
should i increase it to 75 ohms? Can you tell me how can i plot a graph between S11 and frequency? and also what should be a good value for S11? I don't know what else to do with this antenna.
Edgar J. Kaiser
7 years ago
2 giu 2017, 12:52 GMT-4
The antenna's impedance is far away from 50 Ohms (also from 75 Ohms) and furthermore since S11 is almost purely imaginary it is also far from resonance.
Your contributions show that you could do with some textbook reading regarding antenna and transmission line basics. Without this knowledge you won't get very far in your project. Do some research on keywords like antenna, impedance, transmission line, s-parameters, etc.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
