9 nov 2009, 16:48 GMT-5
Hi I have same problem. Did you find any solution for that? Please let me know.
Aram
Aram
14 ott 2010, 02:13 GMT-4
I have the same problem as you had faced. Will you please tell me, how did you solve it ?
Thanks in advance,
Kiran
Thanks in advance,
Kiran
26 gen 2011, 18:06 GMT-5
Hi!
I have a question on the Acoustics module in Comsol, regarding how to set a monopole acoustic source.
I have a point acoustic source characterized by a modulated sin wave:
In Matlab coding,
y=-sin(2.*pi.*Freq.*Ts).*hanning(length(Ts))'
Here, the acoustic source is described in terms of particle displacement, y.
However, I understand that in Comsol, to set a point source, we are supposed to go to Physics > Point settings > Pressure acoustics, and select the type of source as flow, intensity and power.
My question is, how do we convert the description of the point source from displacement to a description in terms of either flow, intensity or power?
Thanks!
Hi.
Have you figured out how to do yet? Thanks~
[QUOTE]
Hi!
In Matlab coding,
Thanks!
[/QUOTE]
Hi.
4 giu 2011, 22:54 GMT-4
i have the similar question for setting the dipole source
8 set 2011, 17:24 GMT-4
Have you figured out the problem yet?
Mads Herring Jensen
COMSOL Employee
13 set 2011, 04:54 GMT-4
Hi all
When entering a flow point source in the frequency domain, the source amplitude S has the dimension m^3/s. In order to set the "radial displacement" U0 of the source you can enter S = U0*acpr.iomega*4*pi.
Best regards
Mads
Hi all
Best regards
Mads
4 feb 2012, 04:09 GMT-5
I too have a problem in something related to the above discussion. If anyone can explain how COMSOL solves the point source problems. The documentation doesn't explain much..
31 lug 2014, 03:13 GMT-4
Then how I can set Q in the monopole source whose dimension is 1/s^2 in 2D.
