third order differential equation
Hi All,
It looks like COMSOL can not handle third order differential equation in Coefficient Form to solve Eigenvalue problem.
I would like to implement this equation:
d^3/dx^3
Any help will be appreciated.
Regards
Sanjay Prabhakar
Post-doc Fellow
Physics, Vanderbilt University
2 Replies Last Post 1 lug 2017, 17:48 GMT-4
Posted: 8 years ago 1 lug 2017, 16:48 GMT-4
Updated: 8 years ago 1 lug 2017, 17:28 GMT-4
Sanjay,
To calculate the higher derivatives, you may define them as a new variable and solve them coupled to the other physics in your model.
To understand how to do this, see the following example by Marc Fernandez Silva:
www.comsol.com/blogs/plotting-spatial-derivatives-magnetic-field/
Hope that they resolve this issue in the newer versions.
Amin,
Sanjay, To calculate the higher derivatives, you may define them as a new variable and solve them coupled to the other physics in your model. To understand how to do this, see the following example by Marc Fernandez Silva: https://www.comsol.com/blogs/plotting-spatial-derivatives-magnetic-field/ Hope that they resolve this issue in the newer versions. Amin,
Posted: 8 years ago 1 lug 2017, 17:48 GMT-4
Thanks Admin,
I think, I figure it out, how to implement third order derivative as follows:
In coefficient form, there is a term \Delta. (....+\gamma)
\Delta can be \partial_x and \gamma can be uxx (second derivative of u w.r.t. x). This gives "third derivative of u w.r.t. x.
Thanks for sending your paper and I will be reading your paper very carefully.
Sanjay
Thanks Admin, I think, I figure it out, how to implement third order derivative as follows: In coefficient form, there is a term \Delta. (....+\gamma) \Delta can be \partial_x and \gamma can be uxx (second derivative of u w.r.t. x). This gives "third derivative of u w.r.t. x. Thanks for sending your paper and I will be reading your paper very carefully. Thanks Sanjay
