Autocad
Hello
Can I design every thing that I want in Autocad then import to the Comsol?
1 Reply Last Post 8 mar 2011, 01:32 GMT-5
Posted: 1 decade ago 8 mar 2011, 01:32 GMT-5
it depends on the CAD modules you have. Autocad makes DXF files you might load into COMSOL for 2D (note you need 2D dxf files in x,y only for v3.5, but 3D DXF files with a Z coordinates are accepted, z value ignored, by v4)
check the main web site for the geometry file conversion / exchange capability matrix
Hi it depends on the CAD modules you have. Autocad makes DXF files you might load into COMSOL for 2D (note you need 2D dxf files in x,y only for v3.5, but 3D DXF files with a Z coordinates are accepted, z value ignored, by v4) check the main web site for the geometry file conversion / exchange capability matrix -- Good luck Ivar
