how to simulate lamb wave in plate in comsol??
Posted 8 mar 2011, 11:18 GMT-5 Acoustics & Vibrations, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 9 Replies
How to simulate lamb wave in comsol??how i will get symmetry mode & antisymmetry mode.??
pls help
Regards!!
Deepak
Hello Deepak
Let me know if you have found a way to work on this.
Regards
Glenston
did anyone find he way to create those wave lambs in aluminum plate?
I'm trying to do the same
thanks
pls help
Regards!!
Deepak
I know this isn't directly telling you how, but this is a paper that is open to viewing on google that demonstrates how to model a lamb wave in COMSOL. I am still trying to get mine to work properly, I seem to just be getting a low frequency wave right now, but this paper has been very helpful.
Also, to be able to see the wave modes, you can select "Probe Table Graph X" (X for the plot #) under "Probe 1D Plot Group X" and do a frequency transformation. You should be able to discern different frequencies. If not, you can probably load the data points onto a data file and run it in MATLAB in a spectrogram or through a filter.
www.comsol.com/papers/11002/
Did you get yours working? I followed the paper's steps but somehow couldn't get any modes, only see the deformation of the beam. Thanks.
xinyao Tang
www.ece.cmu.edu/~dwg/research/Waves25rev.pdf
However to get more help- you need to explain exactly what you want to do. If you are interested in transient simulation, the settings are significantly different for different versions of COMSOL.
As the original posting concerned the (rather ancient) version 4.1, I suggest you create a new topic citing your present version.
D.W. Greve
DWGreve Consulting
I looking to learn ultrasonic wave propagation in comsol. I want to excite S0 mode on the surface of the plate. Could anyone help how I can do it ? also help me what are the physics and boundary conditions i need to use? I am so confused with COMSOL. I am a beginner in it.
Also if possible kindly share some files to learn.
Hi Everyone,
As far as I know, S0 mode is a plate mode. It does not propagate on the surface of the plate. So I guess what you meant is to excite S0 from the surface of the plate? If you apply electrical field to the surface of a piezoelectric plate, depending on its thickness and material, you will get S modes of various orders. They can be "seen" from a dispersion diagram (obtained by taking the 1D Fourier transform of u3 at the plate surface. Remember to use frequency analysis. u3 depends on frequency and x1 position, so 2D array it is). A plate is a symmetric structure so A mode will not be excited in such context. However if your structure is not symmetric, you will also see A modes.
To excite only S0 there are several ways:
Using an IDT at low frequency to excite the mode in a thick plate;
Applying the diplacement fields (u1 and u3) of S0 mode to one edge of the plate. This you have to solve the wave problem in a piezoelectric plate and get the expressions for these fields. So it is a bit more complex than the first way.
Bests,
Ngoc
