explain me what mistake i am doing in my model
Hello
I need help, while simulating my model, I have got following error. Could you please explain me what mistake i am doing in my model.
- Feature: Stationary Solver 1 (sol1/s1)
Failed to find a solution.
Singular matrix.
There are 4113 void equations (empty rows in matrix) for the variable comp1.V2.
at coordinates: (3.93183e-005,4.85007e-005,7e-006), (3.86366e-005,4.90014e-005,7e-006), (3.93183e-005,4.95007e-005,7e-006), (3.90385e-005,5e-005,7e-006), (3.83568e-005,4.95007e-005,7e-006), ...
and similarly for the degrees of freedom (empty columns in matrix).
1 Reply Last Post 25 lug 2017, 02:15 GMT-4
Posted: 7 years ago 25 lug 2017, 02:15 GMT-4
" Singular matrix." means you have not enough (or too many) constraints.
Here it is easy because the message tells you that the variable V2 is
unconstrained.
I cannot tell you more without the model. Is V2 an electric potential? Do
you have a grounding?
Regards
Jens
" Singular matrix." means you have not enough (or too many) constraints. Here it is easy because the message tells you that the variable V2 is unconstrained. I cannot tell you more without the model. Is V2 an electric potential? Do you have a grounding? Regards Jens
