7 years ago
15 ago 2017, 05:24 GMT-4
probably you are not distinguishing correctly in your domains between HT solid domains and HT Fluid domains. By default COMSOL proposes either a Solid domain node or only a Fluid Domain node (depending if you have chosen HT in solid or HT in Fluids as starting point.
You must add a new Domain node with either Fluid or Solid such that you have one of both, and then select the respective domains for Solid and Fluids (all this in ONE same HT physics section.
This would arrange your material properties accordingly to their state solid or fluid.
The type of error you mention comes from a mix of solid material assigned to fluid domains and/or the contrary
7 years ago
15 ago 2017, 08:08 GMT-4
Hello!
Thank you for your reply!
I wanted to point out that I had taken 'Conjugate heat transfer' in the 'Heat transfer' physics tree, I.e., Heat transfer>conjugate heat transfer>turbulent flow>turbulent flow, k-£ (read epsilon).
And I have used time dependent study. And still the problem prevails.
Avinash
Hello!
Avinash
Jeff Hiller
COMSOL Employee
7 years ago
15 ago 2017, 08:27 GMT-4
Updated:
7 years ago
15 ago 2017, 13:53 GMT-4
Hello Avinash,
When the software is complaining that you did not provide a dynamic viscosity for a solid, that means that you have not deselected the part of the geometry occupied by the solid in the Turbulent Flow, k-
node, i.e. you are telling the software that you want the fluid flow equation solved in that part of the geometry - and that requires among other things a dynamic viscosity. Since that's not what you intended to tell the software, deselect the part of the geometry occupied by the solid from the Turbulent Flow, k-
node and you'll be all set.
When the software is complaining that you did not provide a ratio of specific heats for a solid, that means that you have selected the part of the geometry occupied by the solid in the Heat Transfer > Fluid node, i.e. you are telling the software that you want that part of the geometry handled as a fluid for the purpose of heat transfer - and that requires among other things a ratio of specific heats. Make sure that in the Heat Transfer > Fluid node you select only the part of the geometry occupied by the fluid and you'll be all set.
Hello Avinash,
When the software is complaining that you did not provide a dynamic viscosity for a solid, that means that you have not deselected the part of the geometry occupied by the solid in the Turbulent Flow, k-[math]\epsilon[/math] node, i.e. you are telling the software that you want the fluid flow equation solved in that part of the geometry - and that requires among other things a dynamic viscosity. Since that's not what you intended to tell the software, deselect the part of the geometry occupied by the solid from the Turbulent Flow, k-[math]\epsilon[/math] node and you'll be all set.
