temperature change in transient analysis with parametric sweep
Posted 14 mar 2011, 15:10 GMT-4 Heat Transfer & Phase Change Version 4.0 0 Replies
I have two boxes. one is on the other and the top one is same width but very shorter length. I want to extrude the top on the bottom one and make them both same length.
I want to put an initial temperature for it and while it is sweeping over the bottom box its temperature should be effected and decrease because the bottom box itself has a bottom which is in contact with a cooler sink with constant temperature.
I have used the parametric sweep for sweeping it and transient analysis but in each step of parametric sweep the temperature of the top box will be the same temperature as the initial temperature! and also the bottom box again does not consider the temperature history from previous step:(
please help me know how should I do this problem..am I even on right way? I mean parametric sweep and transient analysis is what I need or I need to use something else. please help me.
thanks
Hello Navid Asadiznajani
