7 years ago
27 ott 2017, 04:53 GMT-4
What is the issue where you need Comsol? Mass transfer to the electrode? I suggest you to use the Electrochemistry module, if you have an access to it. It is not necessary but helps a lot. Just remember that the reaction rate r = i/(nF). The problem is that the reaction has a mechanism that affects on the rate law.
BR
Lasse
BR
Lasse
7 years ago
6 nov 2017, 10:31 GMT-5
Hi, Thanks for your reply. I need to know the current density (to perform a cyclic voltammetry) of the platinum electrode when oxidizing glucose. Not complete oxidation, but to gluconic acid.
7 years ago
8 nov 2017, 02:12 GMT-5
Do you have an access to the electrochemistry module? Which version of Comsol are you using? I can provide a model that is made with the Transport of Diluted Species physics, no reaction enegineering is needed. I suppose that the reaction takes place in water. Hence, water does not need to be considered as a reactant because its concentration does not really vary due to the reaction, it is included in the reaction rate constant.
Because the reaction is irreversible, the rate law is
r = k·[glucose] = I/(2F)
Now, the rate constant k depends on the electrode potential in a way that depends on the reaction mechanism; it is not an easy task. Do you have any literature reference about it? Two electrons cannot be transferred simultaneously but in a cascade, and one of the reaction steps is rate determining with only one electron involved.
Best regards
Lasse
Best regards
Lasse
7 years ago
8 nov 2017, 03:56 GMT-5
Updated:
7 years ago
8 nov 2017, 03:57 GMT-5
Hi, Thank you for the reply.
I am using v5.3 and have access to echem. There was a model of a 2D glucose sensor which I had referred to, initially. Instead, I am providing a 3D structure and have included a coarse platinum metal catalyst. One of the referred work is here, http://journals.plos.org/plosone/article?id=10.1371/journal.pone.0038436.
As you said, the refernce also doesn't mention any on electron transfer nature. So, I started proceeding with including the reaction enginnering module and to perform a cyclic voltammetry on the intended structure. I also referred to the example model of 'fuel_cell_cathode'. And I was also considering water as a rectant. Will refer the model which you can provide.
Thanks in advance, Ram.
I am using v5.3 and have access to *echem*. There was a model of a 2D glucose sensor which I had referred to, initially. Instead, I am providing a 3D structure and have included a coarse platinum metal catalyst. One of the referred work is here, [http://journals.plos.org/plosone/article?id=10.1371/journal.pone.0038436](http://).
7 years ago
8 nov 2017, 05:41 GMT-5
I have to digest this for a while...
7 years ago
9 nov 2017, 03:51 GMT-5
A simple model attached in 1D. The mechanism is hidden in the reaction order according to the attached paper.
