Export Parametric Sweep Solutions as Columns in Single File
Posted 30 ott 2017, 10:41 GMT-4 General, Parameters, Variables, & Functions, Results & Visualization Version 5.2a 3 Replies
Hi guys,
I am using the solid mechanics module to analyse the deformation on a surface due to a boundary load from a 'point' source (a Mogi model), with a stationary solver. Please see attached file.
I can create a plot of the values of an expression at set intervals along the surface - in this case using an Edge 2D data set, and the w expression (displacement field, Z component). I can export this data fine, however I encounter problems when I carry out a parametric sweep - as I cannot export the data as I would like.
I can very any of my parameters using the sweep, and produce the same plot as before (but with data pertaining to each stage of the sweep). However, when I come to export this Edge 2D data set with the Parametric solutions selected, I can only export one parameter value at a time.
I am looking to export all of my parameter values at set intervals along the surface, in separate columns - such that I can inspect/compare them and import the data into other programs with ease.
Is there a way to do this? Am I using the wrong approach?
Thanks for any help you can offer.
