Geometry with no domains applicable
I have built a 3D model for multi-layers geometry. The surfaces of the layers were import with interpolation function from excel sheets and built with parametric surfaces, then I built a work plane and extrude to make a block, and convert the block and parametric surfaces into solids to make the multi-layer geology. Also I added some line segments in the block which will be set as edge sources. The trouble comes after forming union, no domains are applicable now, in the bottom messages window it says 'Finalized geometry has 16 boundaries, 34 edges, and 28 vertices.', no domains mentioned. I change the relative repair tolerance value to 1E-7 and it worked well with all expected domains available, but only once, I changed to another values and then changed back to 1E-7 but never worked well again. Anyone knows why domains cannot be defined and how to get rid of this problem
Best regards, Shuhan
0 Replies Last Post 16 nov 2017, 10:09 GMT-5
Hello Shuhan Chen
