input Power
Hello, I am simulated a photonic crystal directional coupler of the wave optics module in the frequency domain. my host is switching normally, but I can not change the input power or better make the input power change in the exiting portion, but the results do not change. I was able to switch between the guides using a range of frequencies. But I need a result with respect to output power. what should I do?
1 Reply Last Post 21 mar 2018, 03:16 GMT-4
Hello Elizete Sabino
Posted: 7 years ago 21 mar 2018, 03:16 GMT-4
hello, Did you get the solution of your above question.. Actually I am also facing similar type of problem regarding the input power
