How to define perturbation in initial conditions?
Hi, I'm remodeling a paper, and I need to define a perturbation in my initial conditions to validate my model with the results in paper. Paper has calculated the stationary form of the equation and then added a 1% perturbation in the sationary results and put the result in the initial condition for the time dependent model, I need to know how I can do this? Exact sentence of the paper: "The initial condition for the transient calculations is generated by applying a locally 1% random perturbation to the anion and cation concentration fields obtained from the steady calculation."
3 Replies Last Post 29 mar 2018, 08:44 GMT-4
Posted: 7 years ago 9 dic 2017, 14:04 GMT-5
Dear Harry,
I recommend you to create two studies for the same model. The first will be the stationary one, and the second will be time-dependent with the initial conditions from the first. Simply define ICs in the second study by using 'withsol' operator and add the perturbation to it.
Dear Harry, I recommend you to create two studies for the same model. The first will be the stationary one, and the second will be time-dependent with the initial conditions from the first. Simply define ICs in the second study by using 'withsol' operator and add the perturbation to it.
Posted: 6 years ago 7 mar 2018, 09:39 GMT-5
Hi, I have the same problem. How to I add the perturbation? The initial condition allows me to choose only from one of the solutions. Thank you
Posted: 6 years ago 29 mar 2018, 08:44 GMT-4
Dear Harry,
Hello Dear Vasily I don't know how to use the so called 'withsol' operator, would you please give me an example? or any instruction on how to use it in IC?
>Dear Harry, > >I recommend you to create two studies for the same model. The first will be the stationary one, and the second will be time-dependent with the initial conditions from the first. Simply define ICs in the second study by using 'withsol' operator and add the perturbation to it. Hello Dear Vasily I don't know how to use the so called 'withsol' operator, would you please give me an example? or any instruction on how to use it in IC?
