from a laminar static mixer to another tube
Posted 11 dic 2017, 08:10 GMT-5 Computational Fluid Dynamics (CFD), Geometry, Modeling Tools & Definitions Version 5.3 0 Replies
Hello everyone!
At first thank you for your time and suggestions.
I'd like to model a gas flow in a pipe with a velocity not only depending from only one direction (i.e. not a irrotational flow). I manged to solve the model laminar_static_mixer and it gave the behavior I'm interested in.
Now I'd like to use the outlet velocity profile to start a new pipe in 3D and I also inspired myself from the model flow-through-a-pipe-elbow with the general extrusion. From the Geometric entity level list, I choosed Boundary and select the outlet boundary On the Destination Map section: x=x, y=y and z=12*Ra (the altitude of the outlet of the pipe) For my 2nd component inlet I used: comp1.genext1(w) for uz for example I lauched the first and second studies selecting only one composant and, for the second one indicating that some variables has already been solved. No errors but the velocity is equal to 0 everywhere... My first question: is there a way to plot the general extrusion data I'm interested in to view if I'm wrong somewhere?
Then I tried to export the velocity profile to a file. I managed to export it in another comsol model but the dimemsions are in "mm" and the imported file is read as "m". It should not be important however when I wrote as intlet velocity profile "u_import(x x 1000, y x 1000)" I got another error: Undefined value found in x noPeriodthe constraint residual vectorcolon NaN or Inf in vector
Is someone better than me to model this extrusion?
Regards
Hello Fabien Dhainaut
