Internal Damping in Transient Solid Mechanics
Hello All,
In Comsol version 4.1, I would like to know how we can assign Rayleigh damping or loss factor damping coefficients to the material properties in the Solids Mechanics while performing transient analysis, like we used to do in 3.x versions.
Thanks in advance,
Onur
4 Replies Last Post 9 feb 2012, 23:41 GMT-5
Posted: 1 decade ago 4 apr 2011, 04:36 GMT-4
right click the "Linear Elastic" node and add "Damping", and set accordingly the selections and data
In general in V4 right click all nodes until lowest level, be aware that new sub nodes might appear and change depending on settings in the main physics node
Hi right click the "Linear Elastic" node and add "Damping", and set accordingly the selections and data In general in V4 right click all nodes until lowest level, be aware that new sub nodes might appear and change depending on settings in the main physics node -- Good luck Ivar
Posted: 1 decade ago 4 apr 2011, 04:41 GMT-4
Hello Ivar,
Thank you for your quick response.
Onur
Hello Ivar, Thank you for your quick response. Regards, Onur
Posted: 1 decade ago 9 feb 2012, 12:15 GMT-5
It seems that in transient solid mechanics the damping is not taken into account. I tried to introduce a structural loss factor but whatever the value i put in the subnode "Damping" i still have the same results.
I also introduced a complex young modulus but i got the same results. Did you face this problem?? i'am on Comsol 4.2 and 4.2a
In frequency domaine evrything is ok!
Hi, It seems that in transient solid mechanics the damping is not taken into account. I tried to introduce a structural loss factor but whatever the value i put in the subnode "Damping" i still have the same results. I also introduced a complex young modulus but i got the same results. Did you face this problem?? i'am on Comsol 4.2 and 4.2a In frequency domaine evrything is ok! Thanks
Posted: 1 decade ago 9 feb 2012, 23:41 GMT-5
Structural loss factor damping works only in the frequency domain. You can use Rayleigh damping, or a material model that has built in damping, such as viscoelastic.
Nagi Elabbasi
Veryst Engineering
Structural loss factor damping works only in the frequency domain. You can use Rayleigh damping, or a material model that has built in damping, such as viscoelastic. Nagi Elabbasi Veryst Engineering
