Loop antenna
Hi I want to simulate a simple loop antenna which is made of copper. In this case I modelled a torus (360 deg), but I don't have any idea how to excite it. When I try adding port only errors occur. I will be grateful for any help.
4 Replies Last Post 2 feb 2018, 07:35 GMT-5
Posted: 7 years ago 27 gen 2018, 23:54 GMT-5
Cut a thin piece out of the loop and put a lumped element port there, with the direction of the imposed current (or voltage) from one side of the cut to the other. The "height" is the length of your cut segment, the "width" is 2* pi*r, where r is the small radius (i.e., of the wire, not of the overall loop).
Posted: 7 years ago 28 gen 2018, 13:07 GMT-5
Could you please show me how to do that? I am trying but the effect is disappointing.
Posted: 7 years ago 30 gen 2018, 00:04 GMT-5
I encourage you to post your file to this forum. Then, I or others can look at it and one of us may tell you what is wrong.
Posted: 7 years ago 2 feb 2018, 07:35 GMT-5
I have the similar issue. I've modelled a loop antenna and when I excite it with lumped port, I receive different S11 result in comparison to CST. Both works at the same frequency but in COMSOL I see mismatch in my design. in CST: @ 2.4 GHz ---> S11=-30 dB In COMSOL: @ 2.4 GHz ---> S11=-15 dB
Can anyone help me?
Hi I have the similar issue. I've modelled a loop antenna and when I excite it with lumped port, I receive different S11 result in comparison to CST. Both works at the same frequency but in COMSOL I see mismatch in my design. in CST: @ 2.4 GHz ---> S11=-30 dB In COMSOL: @ 2.4 GHz ---> S11=-15 dB Can anyone help me? Thanks
