Error detected during principal component evaluation
Hi all,
what is the meaning of that error message.
I simulate a case in nonisothermal flow and use this for a single ac/dc simulation. This works fine. Just before I want to iterate both physics the message appears and the solver breaks.
"Error detected during principal component evaluation. Complex tensor field"
Best regards, Marcel
3 Replies Last Post 14 dic 2015, 14:43 GMT-5
Posted: 1 decade ago 6 apr 2011, 08:31 GMT-4
Hi again,
I try to describe the problem again: I want to solve stationary non-isothermal flow problem. Additionally, I solve an AC problem of electrically conducting liquid in frequency domain. The time-averaged Lorentz force distribution serves as a source term for the flow problem. Additionally the electrical conductivity depends on temperature.
Therefore, I solve the stationary fluid dynamic problem without the EM forces at first. Then I want to calculate the coupled simulation of both stationary fluid dynamics and harmonic EM simulation.
I use a stationary study tab and select frequency domain in the mef settings. Then the error ("Error detected during principal component evaluation. Complex tensor field") occures.
When I use stationary for both physics (in other words coupling DC MEF and fluid dynamics) it starts iterating.
How can I couple a stationary and a frequency domain problem in v4.1? In older versions I never had such problems.
Best regards
Hi again, I try to describe the problem again: I want to solve stationary non-isothermal flow problem. Additionally, I solve an AC problem of electrically conducting liquid in frequency domain. The time-averaged Lorentz force distribution serves as a source term for the flow problem. Additionally the electrical conductivity depends on temperature. Therefore, I solve the stationary fluid dynamic problem without the EM forces at first. Then I want to calculate the coupled simulation of both stationary fluid dynamics and harmonic EM simulation. I use a stationary study tab and select frequency domain in the mef settings. Then the error ("Error detected during principal component evaluation. Complex tensor field") occures. When I use stationary for both physics (in other words coupling DC MEF and fluid dynamics) it starts iterating. How can I couple a stationary and a frequency domain problem in v4.1? In older versions I never had such problems. Best regards
Posted: 1 decade ago 7 apr 2011, 03:04 GMT-4
I would suggest to check with "support", and to be sure you use the latest release/patch (and pls report back here)
Hi I would suggest to check with "support", and to be sure you use the latest release/patch (and pls report back here) -- Good luck Ivar
Posted: 9 years ago 14 dic 2015, 14:43 GMT-5
I have the same problem. Did you have any chance to solve it?
I will apriciate that if you can help me out here
Hossein
Hi I have the same problem. Did you have any chance to solve it? I will apriciate that if you can help me out here Hossein
