Decrease File Size via Solution Removal
All -
I have a simple question that I cannot find the answer to in other threads. In version 3.5a, I would like to remove the calculated solution to decrease the file size. After calculation, the file is approximately 35 MB but I would like to get it as small as possible for emailing. The only way I know now is to recreate the model in a new file without solving it - surely there is another way.
Thanks for the help!
Mark
2 Replies Last Post 21 apr 2012, 11:12 GMT-4
Posted: 1 decade ago 7 apr 2011, 01:40 GMT-4
you have the "File Reset Model" which clears the solution AND the mesh, which is often annoying in 3.5 as it can be quite some work to regenerate it ( nicely improved in V4 just for that it's worth changing).
Nov I cannot remember anymore if there were a trick to clear only the solution
Hi you have the "File Reset Model" which clears the solution AND the mesh, which is often annoying in 3.5 as it can be quite some work to regenerate it ( nicely improved in V4 just for that it's worth changing). Nov I cannot remember anymore if there were a trick to clear only the solution -- Good luck Ivar
Posted: 1 decade ago 21 apr 2012, 11:12 GMT-4
Thanks for sharing!
Thanks for sharing!
