regarding change of frequency and ploting graph in square spiral inductor
sir,
i have created square spiral inductor
please tell me how to plot graphs at variable frequency
and also determining the value of inductance and q factor with the help of graph
1 Reply Last Post 10 apr 2011, 05:35 GMT-4
Posted: 1 decade ago 10 apr 2011, 05:35 GMT-4
pls use the tabs to specify the version and the physics you use, as the replies will vary
for v4, you plot easiest via a "Definition Probe ..." or a "Results Derived Value ....
For a frequency domain solver you will have a scan over the frequency values (if you select a range) and then you can generate a plot by hitting the icon on the upper Table GUI border.
Be sure you have defined a GND boundary on one side of your inductor, and a voltage source of something <>0 on the other side, or used a lumped port/terminal
Hi pls use the tabs to specify the version and the physics you use, as the replies will vary for v4, you plot easiest via a "Definition Probe ..." or a "Results Derived Value .... For a frequency domain solver you will have a scan over the frequency values (if you select a range) and then you can generate a plot by hitting the icon on the upper Table GUI border. Be sure you have defined a GND boundary on one side of your inductor, and a voltage source of something 0 on the other side, or used a lumped port/terminal -- Good luck Ivar
