Inverted Mesh problem
I designed MEMS Pillar which is as vertical shape of MEMS cantilever with COMSOL 3.5a version. The design is very similar to sample cantilever that is offered from COMSOL. I used Silicon for the beam instead of Polysilicon with Aluminum above Silicon. I followed the exact tutorial and got a problem with "Inverted Mesh". The error is as follow:
Error: 7248
Undefined value found.
Detail:
Exception:
com.femlab.jni.FlNativeException: Undefined value found Solvermodel
Stack trace:
at solvermodel.cpp, row 1837, (Undefined value found in the equation residual vector.
There are 27 degrees of freedom giving NaN/Inf in the vector for the variable u
at coordinates: (2e-006,0.00032625), (2e-006,0.000328125), (2e-006,0.00033), (2e-006,0.000331875), (2e-006,0.00033375), ...
There are 27 degrees of freedom giving NaN/Inf in the vector for the variable v
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
Progress - Solve Problem
Warning: Inverted mesh element near coordinates (0, 0)
Please simulate the design after download the attached file below and let me know where I should fix the model.
Thank you for your consideration.
Sincerely,
Doyoung Kim
1 Reply Last Post 12 apr 2011, 01:41 GMT-4
Posted: 1 decade ago 12 apr 2011, 01:41 GMT-4
the inverted mesh info is a warning, not per say an error, you have something else, such as a missing BC or not many enough BC's in your model, which is giving your the NaN's
Try to solve one physics at the time to identify what is wrong, I had a quick glance, but did not see it, on the other hands 3.5 is old so I'm no longer that sharp to point out the hidden errors any longer
Hi the inverted mesh info is a warning, not per say an error, you have something else, such as a missing BC or not many enough BC's in your model, which is giving your the NaN's Try to solve one physics at the time to identify what is wrong, I had a quick glance, but did not see it, on the other hands 3.5 is old so I'm no longer that sharp to point out the hidden errors any longer -- Good luck Ivar
