Magnetic field Ac sweep how?
hi to all
i have a model with 2 Magnets that i defined them with a constant magnetization
and i have a constant Magnetic field.
i want it to be AC what should i do
is there a possibility those magnets will have ac field?
can i create ac magnitization?
or i should look at the frequancy simulation?
and then how will i implement this ac magnetic field ?
are any other ways
Best regards
Arye
2 Replies Last Post 13 apr 2011, 18:07 GMT-4
Posted: 1 decade ago 13 apr 2011, 15:50 GMT-4
as you have not stated version or physics, I assume V4 (latest patch) and MF physics. Then your are best out with a frequency domain analysis. If you check the formulas, you will see that the "i*omega" is multiplying A. This should allow you to define the amplitude of the fields, but the results are mainly average per amplitude.
however you might want to scan the frequency domain
Hi as you have not stated version or physics, I assume V4 (latest patch) and MF physics. Then your are best out with a frequency domain analysis. If you check the formulas, you will see that the "i*omega" is multiplying A. This should allow you to define the amplitude of the fields, but the results are mainly average per amplitude. however you might want to scan the frequency domain -- Good luck Ivar
Posted: 1 decade ago 13 apr 2011, 18:07 GMT-4
Thanks a lot for your fast response
you right about version 4.1 and MF physics
and yes i'll want to do a sweep on those frequncies in the future
but first of all i want to see it one specific freq is ok.
is the Magnets magnitization formula is going to be ac(in your advice)? or you ment to somthing else? some else way to create the magnetic ac field in the space
thanks again
and
Arye
Thanks a lot for your fast response you right about version 4.1 and MF physics and yes i'll want to do a sweep on those frequncies in the future but first of all i want to see it one specific freq is ok. is the Magnets magnitization formula is going to be ac(in your advice)? or you ment to somthing else? some else way to create the magnetic ac field in the space thanks again and Best regards, Arye
