18 apr 2011, 14:40 GMT-4
I would like to know too ;)
In 3.5 you had eiter autoscale or "use screen scale" forthe overall view, but then I'm not sure the deformation was controllable, neither not the scale color code adapting between images
In V4 I'm also lacking better control, hope something more advanced will come in next release
3 dic 2012, 12:10 GMT-5
I too have this problem when trying to export an animation of groundwater flow. The flow vectors I have plotted arbitrarily change length during the exported GIF. This is one annoying bug!
3 dic 2012, 14:21 GMT-5
I have understood the programmers call these things "features", and not "bugs" as there is nothing wrong/false, it's just not how many of us had expected the display to run, but having a" freeze scale" option would be an even better "feature" ;)
4 dic 2012, 10:47 GMT-5
I have just seen a similar problem in my animations (when exporting to gif or flash). Exporting with a legend (in my case the changing parameter between frames is simulated time) causes the periodic rescaling of the frames depending on if the time appearing at the top has 3 (e.g. t = 1.31s) or 2 digits ((e.g. t = 1.3s).
Those animations are mainly used for the presentation of my results, this dynamic rescaling resulting in kind of a flickering (or beating) video makes the export animation option less attractive to use. If this is an issue (missing option to keep the digits of my time parameter constant) of the software, I would be happy to see an improvement in the next version. Else please let me know what I am doing wrong.
4 dic 2012, 11:09 GMT-5
in the bottom of the Animation tab there is a "Synchronisze scales between frames" that is by default on, turning it off might give you your effects
5 dic 2012, 05:06 GMT-5
OK,
Apparently version 4.3a does have such a button, version 4.3 does not.
Matias
OK,
Matias
9 years ago
11 lug 2016, 06:09 GMT-4
There is another level of settings for the graphs, for instance under Stress (solid) > Surface 1 > Deformation where this setting is located.
8 years ago
17 giu 2017, 05:10 GMT-4
Updated:
8 years ago
Follow this
Results-->Stress-->Surface 1-->Deformation-->You will find Scale over there. Just change the scale factor to 1. :)
Follow this
