7 years ago
15 mar 2018, 08:53 GMT-4
Could you please provide the model, or the link to the Single Crack example ?
Cristina Aguanell Garrido
7 years ago
15 mar 2018, 09:01 GMT-4
Yes of course.
https://www.comsol.com/model/single-edge-crack-988
And thank you for your reply
Yes of course.
7 years ago
15 mar 2018, 10:35 GMT-4
I think the prescribed displacement on the x axis, at the crack tip point, is to prevent the rigid body movement along the X-axis. I expect that the result will be the same if this constraint is applied to any other point of the geometry. Maybe, this point is chosen to have zero displacement at the crack tip, which is easier for the post-processing.
It is not to block the propagation of the crack, because it is a quasi-static computation. The propagation of the crack is determined afterward by energy consideration (Griffith's criterion).
It is not this simple to model the actual crack propagation with a finite propogation velocity for instance.
I do not see any difference for a 3-points bending case... except that an initial crack length as to be specified relative to the thickness of the beam, and that the beam thickness as to be small relative to its length...
best regards,
best regards,
