CFD-Two phase flow, Level set
Hi everybody
I'm new user for COMSOL (4.1), I would like to model two phase flow, level set. I do not how to handel this problem. If any body has an example similar to this please send it to me to practice.
3 Replies Last Post 25 apr 2011, 15:31 GMT-4
Posted: 1 decade ago 25 apr 2011, 03:31 GMT-4
have you checked the model library ? (and have you updated it via the specific command in V4 ?
there were I believe also some examples in 3.5, but if you are new to COMSOL and to v4, then it will be I believe confusing to read too much about the old version, as the new approach is different (better in my view, once understood)
Hi have you checked the model library ? (and have you updated it via the specific command in V4 ? there were I believe also some examples in 3.5, but if you are new to COMSOL and to v4, then it will be I believe confusing to read too much about the old version, as the new approach is different (better in my view, once understood) -- Good luck Ivar
Posted: 1 decade ago 25 apr 2011, 14:15 GMT-4
Thank you Mr. Ivar for your time,
I went through the model library and the documentations regarding the level set, but to build a model is not so easy. That is why I'm asking for examples (ready modles) to learn from it.
Thanks.
Thank you Mr. Ivar for your time, I went through the model library and the documentations regarding the level set, but to build a model is not so easy. That is why I'm asking for examples (ready modles) to learn from it. Thanks.
Posted: 1 decade ago 25 apr 2011, 15:31 GMT-4
unfortunately I have had no time to test out the level set, it's not really within my field of models I'm asked to run (yet) so I cannot help more, but there are other out there ;)
You could also try to look over the conference papers, or some of the books (see the list in the main site, search for "books")
Hi unfortunately I have had no time to test out the level set, it's not really within my field of models I'm asked to run (yet) so I cannot help more, but there are other out there ;) You could also try to look over the conference papers, or some of the books (see the list in the main site, search for "books") -- Good luck Ivar
