Acoustic shell interaction
Posted 12 apr 2018, 05:21 GMT-4 Acoustics & Vibrations Version 5.3a 0 Replies
Acoustic source is in the water and it is 30 mm away from the centre of hollow aluminium cylinder of thickness 0.01mm , diameter 5mm and height 20 mm and cylinder is filled with water. I want to find the acoustic pressure at the centre of hollow aluminium sphere. How to select water inside the hollow aluminum cylinder. I have attached the comsol file
Hello Bipin Kumar
