2 decades ago
20 nov 2009, 04:45 GMT-5
Is there any work around way to anlayze the speaker membrane large deformation. The thickness of the membrane is very small comparing to its size. Please help. Many thanks.
2 decades ago
20 nov 2009, 07:19 GMT-5
You are asking an interesting question there about large deformations theory and the simplified shell models. These type of questions are typicaly what I ask support.
Normally with bulk structural mode the large deformations uses Greens stress, versus Engierring stress for small deformations, but when using shells, isn't all this predefined ?
Il you check the smeref.pdf doc, you see that large deformations is mentionned for trusses, but not explicitely for beams nor for shells !
When you open the shell and beam modes in 2D or 3D [V3.5a] there is NO option for large deformations. therefore I would conclude that the default shell items are NOTcompatible with large deformations.
I would use bulk 3D, even if correct meshing is somewhat more complex.
9 years ago
30 dic 2015, 03:45 GMT-5
I have the same question.
When I calculate the force vs deformation for a ultrathin membrane, such as graphene, which model is most suitable? 3D membrane? or 2D plate is fine too?
