Exporting data from boundary: Bug!!??
Hi everyone,
I don't know if I have to say that's a bug or no in COMSOL??
I have noticed that when I try to plot a variable along some Boundary by using domain plot parameters. Comsol plots them correctly. But if I want to export the data as ASCII file, the software exports them but not in the right order e.g. not in ascending order. So I had to rearrange the data again. It is so weird !!
P.S: Along this boundary, the mesh is moving (it is a time dependent problem) So I am suspecting this point!!
Anyone has faced this problem before??
Cheers,
5 Replies Last Post 21 nov 2009, 07:40 GMT-5
Posted: 2 decades ago 20 nov 2009, 08:32 GMT-5
I have also seen this for long listings, it's correct, and I forgot to submit that case to support the other day.
These are typical cases to submit to SUPPORT.
I believe this has to do with the memory management, have seen similar problems in other softwares, for their graphics too, could be a Java issue.
Mostly you find out how to reorder the data by hand but its annoyng, I agree.
This is one of the very few true "bugs" I have seen so far over the last years of my COMSOL use, most other so called bugs I have observed are misunderstandings on the model build-up and behaviour, we apply quite some level of physics here ;)
Another way to get the data is to catch the command in the history file and import the variables directly into Matlab
For me a good example to submit to support, but send them a model with the error so they can easily reproduce it, otherwise it's difficult for them to understand
Hi I have also seen this for long listings, it's correct, and I forgot to submit that case to support the other day. These are typical cases to submit to SUPPORT. I believe this has to do with the memory management, have seen similar problems in other softwares, for their graphics too, could be a Java issue. Mostly you find out how to reorder the data by hand but its annoyng, I agree. This is one of the very few true "bugs" I have seen so far over the last years of my COMSOL use, most other so called bugs I have observed are misunderstandings on the model build-up and behaviour, we apply quite some level of physics here ;) Another way to get the data is to catch the command in the history file and import the variables directly into Matlab For me a good example to submit to support, but send them a model with the error so they can easily reproduce it, otherwise it's difficult for them to understand Good luck Ivar
Posted: 2 decades ago 20 nov 2009, 18:08 GMT-5
I had the same problem earlier this week. Spent a few hours trying to figure out what was going on. Eventually I just had Matlab order them correctly.
I should point out that your problem was with exporting it as an ASCII file, but I actually encountered the same problem with the posteval function on boundaries. Its annoying, but at least there's an easy workaround.
Mike
I had the same problem earlier this week. Spent a few hours trying to figure out what was going on. Eventually I just had Matlab order them correctly. I should point out that your problem was with exporting it as an ASCII file, but I actually encountered the same problem with the posteval function on boundaries. Its annoying, but at least there's an easy workaround. Mike
Posted: 2 decades ago 21 nov 2009, 03:05 GMT-5
I hope some COMSOL developpers are passing by here to !!
Hi I hope some COMSOL developpers are passing by here to !! Ivar
Posted: 2 decades ago 21 nov 2009, 05:29 GMT-5
Hi again,
aother way out (hope we do not have the same error is described at p489 [V3.5a] of the User guide:
"Exporting Postprocessing Data to a File"
Hi again, aother way out (hope we do not have the same error is described at p489 [V3.5a] of the User guide: "Exporting Postprocessing Data to a File" Ivar
Posted: 2 decades ago 21 nov 2009, 07:40 GMT-5
Thanks Ivar and Mike,
There is another problem in the same context: When exporting multiple curves in one plot, the data of the different curves are not separated also, which means that you have to do it by yourself!!!
Yes, I hope that some COMSOL developers are passing by this thread.
Cheers,
Thanks Ivar and Mike, There is another problem in the same context: When exporting multiple curves in one plot, the data of the different curves are not separated also, which means that you have to do it by yourself!!! Yes, I hope that some COMSOL developers are passing by this thread. Cheers,
