Heating transfer water
Hi!
I have made a heat transfer 3D-model of a plastic container which contains water. There are also 2 blocks of iron in the water. This model is time dependent, I want to see how the temperature of the water varies as time goes on. To do this, I have given a high temperature value to the blocks of iron (1000 K, while the water has a value of 273 K).
The only problem; the temperature of the whole system doesn't change at all! I have seeked help to my teacher, but he also doesn't know why, can you help me with this problem? If so, please check the attachement.
Thank you in advance!
1 Reply Last Post 24 mag 2018, 03:15 GMT-4
Yara Soares COMSOL Employee
Posted: 7 years ago 24 mag 2018, 03:15 GMT-4
Dear Rishi,
If you have an Access Account and access to an active COMSOL license, I would suggest sending your question to support@comsol.com for a swift reply. If you don't have access to a license, please contact me and we can discuss the possibility of a trial version.
Met vriendelijke groet, Best regards,
Yara Soares
COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212
www.comsol.nl | yara.soares@comsol.com
Dear Rishi, If you have an Access Account and access to an active COMSOL license, I would suggest sending your question to support@comsol.com for a swift reply. If you don't have access to a license, please contact me and we can discuss the possibility of a trial version. Met vriendelijke groet, Best regards, Yara Soares -------------------------------------------------------------------------- COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212 www.comsol.nl | yara.soares@comsol.com -----------------------------------------------
