EC and MF coupling
Marco Túlio Alves Êvo
The below post is related to an archived discussion
I'm trying to couple the physics Magnetic Field and Electric Currents in Comsol to study a time dependent problem. I already done the advise gived by Mr. Magnus Olsson in the last post. That is, I had set up the EC interface with an applied voltage and then I had set up the MF interface with the total EC current density as an "external current density" to make the coupling. However, when I look the simulated current in the MF, it oscillates with some kind of an offset and take several cycles to converge to the expected solution. On the other hand, if I decrease the source frequency until the skin effect is negligible, the current converges to the expected solution in just few cycles. I'm using the default solver (Segregated). Perhaps I have to configure it in a better way that I don't know yet.
So, have someone an idea to fix my problem? Do I have to do some other trick to couple this two physics?
Thanks a lot.
0 Replies Last Post 6 giu 2018, 08:50 GMT-4
Hello Marco Túlio Alves Êvo
