Meshing Problem : Beginner "Acoustic Structure Interaction"
Hi everybody,
I've just started working on COMSOL MPH on an Acoustic/Structure Interraction. After repairing the geometry, i wanted to mesh it to know if it's well repaired, but i had several errors and warning due to narrow regions and small edges ... , the geometry is quit complicated so i wanted to know if i can have an advise please , just to help me start the work properly
Nb: I'm a beginner on the field
Thank you for your time
2 Replies Last Post 13 lug 2018, 03:34 GMT-4
Riccardo Roberto De Lucia
Posted: 6 years ago 12 lug 2018, 11:20 GMT-4
Hi, I am new to acoustics too. As far as I have understood, for FEM analyses, the general good practice is to start from a coarse mesh defined all over the model with maximum element size equal to at least one fifth of the wavelength of the fluid you are simulating in. Then you can refine the mesh for the structure to a finer level. Hope it helps!
Riccardo
Hi, I am new to acoustics too. As far as I have understood, for FEM analyses, the general good practice is to start from a coarse mesh defined all over the model with maximum element size equal to at least one fifth of the wavelength of the fluid you are simulating in. Then you can refine the mesh for the structure to a finer level. Hope it helps! Riccardo
Posted: 6 years ago 13 lug 2018, 03:34 GMT-4
Hi Riccardo,
Thank you very much, this was very helpfull for me. I'll continue learning via the application library !
Have a nice weekend
Yasser
Hi Riccardo, Thank you very much, this was very helpfull for me. I'll continue learning via the application library ! Have a nice weekend Yasser
