Induced Current
Posted 5 lug 2018, 14:19 GMT-4 Electromagnetics, Low-Frequency Electromagnetics, Studies & Solvers Version 5.3 0 Replies
Dear All,
I'm trying to calculate the EM properties of a detector that admits a cylindrical symmetry. One thing I'd like to find is the current density that is induced by a changing magnetic field sourced by an external current density j. At the end of the day, I want j~cos(t), and when I put this into the simulation I get the expected fields as well as an induced current that has a semi-reasonable behavior (I haven't checked the numbers yet).
However, I made j=1, which gives me the expected induced fields, but this change also gives me an unexpected current density, in that there is one there. While the induced EMF is 0, there is a non-negligible current density. Could someone explain to me why this is? The detector is supposed to be made of a superconductor, so I amped the conductivity of the material way up. Is it possible that there is a small error in the induced Efield that is being amped up by the high conductivity and causing this anomalous current density? I had to make the mesh extremely coarse because otherwise run times are too long, so this might also cause further error.
I've attached the simulation file below.
-Best, Henry
Hello Henry Froland
