Thermofluidic Modelling of hydrogen absorption in metal hydride bed
For learning purposes, I was trying to do the this project Thermofluidynamic Modelling of hydrogen absorption and desorption in a LaNi4.8Al0.2 Hydride Bed at www.comsol.com/papers/7311/download/Lombardo.pdf (published in Comsol conference 2009 Milan). Except instead of two subdomain, I have only one domain containing the porous media and hydrogen enters the cylender through inlet. I am using the Darcy Law's Module and Heat transfer in Porous medium module. For kinetic expression, I have defined the formula in the definition section. I am using the same values and formulas defined in this paper. When I tried to run the program, I get errors which are associated with heat source definition and hydrogen mass absorption rate definition. Furthermore, I would like to see how would you plot the temperature and internal pressure plots which are published in the paper.
I have attached the file. Thank you in advance.
14 Replies Last Post 27 mag 2016, 15:48 GMT-4
Hello Muhammad Assad
Posted: 1 decade ago 26 nov 2011, 04:44 GMT-5
Dear colleague,
Did you solve the problem? In case you did, please send the improved model.
Regards
Dear colleague, Did you solve the problem? In case you did, please send the improved model. Regards
Posted: 1 decade ago 9 feb 2013, 07:22 GMT-5
Did you get the improved model?
If YES, can i have it too?
Hi Did you get the improved model? If YES, can i have it too?
Posted: 10 years ago 28 ago 2014, 12:28 GMT-4
There are multiple syntax errors (missing * sign, m63 instead m^3) or maybe they've appeared when i opened the file with comsol 4.3
Also, you have circular dependency: rhoss depends on Qm wich depends on phoss
You'll need to solve equation of hydrogen concentration (chemical reaction's rate equation). Look at appropriate articles, for example, M. GAMBINI, METAL HYDRIDE ENERGY SYSTEMS PERFORMANCE EVALUATION. PART A: DYNAMIC ANALYSIS MODEL OF HEAT AND MASS TRANSFER
I'm currently working on almost same case, but it keep giving me an error "trying to find logarithm of negative number" while the expression is log(abs(p)) !...
There are multiple syntax errors (missing * sign, m63 instead m^3) or maybe they've appeared when i opened the file with comsol 4.3 Also, you have circular dependency: rhoss depends on Qm wich depends on phoss You'll need to solve equation of hydrogen concentration (chemical reaction's rate equation). Look at appropriate articles, for example, M. GAMBINI, METAL HYDRIDE ENERGY SYSTEMS PERFORMANCE EVALUATION. PART A: DYNAMIC ANALYSIS MODEL OF HEAT AND MASS TRANSFER I'm currently working on almost same case, but it keep giving me an error "trying to find logarithm of negative number" while the expression is log(abs(p)) !...
Posted: 10 years ago 16 set 2014, 16:48 GMT-4
I did something to the file and tried to improve it.
The main problem is in the heat source equation and inconsistent units.
If you wish we can work that together.
I am also trying to so that using FlexPDE software.
I did something to the file and tried to improve it. The main problem is in the heat source equation and inconsistent units. If you wish we can work that together. I am also trying to so that using FlexPDE software.
Posted: 10 years ago 10 ott 2014, 09:53 GMT-4
If interested I can send you the file by e-mail.
Posted: 9 years ago 14 gen 2015, 06:47 GMT-5
yes, please send me files.
Posted: 9 years ago 15 gen 2015, 07:05 GMT-5
Try out with some constant values...may be you will get results..i am also hydrogen storage models..till now my results are not satisfactory....
Posted: 9 years ago 29 mar 2015, 14:51 GMT-4
what is your e-mail?
Posted: 9 years ago 30 mar 2015, 08:39 GMT-4
e-mail adress: ihilali@gmail.com
Posted: 9 years ago 21 apr 2015, 03:31 GMT-4
I used comsol for the same problem, can you please send me the model?
Many thanks.
Hi I used comsol for the same problem, can you please send me the model? Many thanks.
Posted: 9 years ago 21 apr 2015, 03:38 GMT-4
I downlod your model and i think there is a lot of thing miss in your model.
me i used the PDE for hydrogen absorption rate.
my problem is just related with initial and bondary conditions.
if you want, we can work together.
I downlod your model and i think there is a lot of thing miss in your model. me i used the PDE for hydrogen absorption rate. my problem is just related with initial and bondary conditions. if you want, we can work together.
Posted: 9 years ago 21 apr 2015, 05:33 GMT-4
Posted: 9 years ago 28 mag 2015, 14:54 GMT-4
What is your e-mail? Mine is jehadyam@yahoo.com
Posted: 8 years ago 27 mag 2016, 15:48 GMT-4
Did you solve your problem with the metal hydride model?
