can comsol draw a geometry consist of hundreds different rectangulars?
My geometry consist of over hundreds rectangular, each has theri own width and with same height. the questions is whether i can input all the width data in my model and let comsol draw this geometry automaticly or need i do it in matlab?
2 Replies Last Post 25 nov 2009, 10:41 GMT-5
Posted: 1 decade ago 25 nov 2009, 10:14 GMT-5
My bet is that Matlab is going to be your best bet. Just define an iterative loop and create each rectangle individually.
On the bright side, if you don't want to do your entire simulation, you can always write an m-file that just creates the geometry. Then you can import it into Comsol and use their interface to do everything else.
Good luck,
Mike
My bet is that Matlab is going to be your best bet. Just define an iterative loop and create each rectangle individually. On the bright side, if you don't want to do your entire simulation, you can always write an m-file that just creates the geometry. Then you can import it into Comsol and use their interface to do everything else. Good luck, Mike
Posted: 1 decade ago 25 nov 2009, 10:41 GMT-5
hi, Mike, thanks for your reply, I am also thinking let matlab maybe work better, but for my each rectangular, i have the different boundary conditons values. they are from my experiment results. that make my confused can i connect comsol with mablab about this?
