Empty parameter list
I am solving a solid mechanics problem and since it is not working and is nonlinear, I am trying the parametric sweep to increase the body force slowly.
However, I am getting the error Empty parameter list but have no idea what it means and what I did wrong.
If you could shed some light on this, I would greatly appreciate.
Thanks a lot.
2 Replies Last Post 23 mag 2011, 12:56 GMT-4
Posted: 1 decade ago 20 mag 2011, 07:47 GMT-4
I don't know anything about the actual physics you are simulating, but at least one thing caught my attention. Your parameter sweep values go from 0 to -200, that is, a negative value. Then, the step size must be -5, not +5, so that the sweep goes into the right direction.
Posted: 1 decade ago 23 mag 2011, 12:56 GMT-4
Hi Henrik,
Thank you very much for the help. Indeed that is the error. I have corrected it!
Thanks again, much appreciated!
Haolin
Hi Henrik, Thank you very much for the help. Indeed that is the error. I have corrected it! Thanks again, much appreciated! Haolin
