Studying deformation in a porous structure (Brinkman equation)
i am working on studying stress and deformation in porous media as fluid flows through it ... i tried using solid mechanics, but it considers the porous structure as impenetrable solid. And if i use proroelasticity, it uses Darcy's law, but the flow inside the porous structure is governed by Brinkman eqaution. Is there a way around this problem?
- JD
1 Reply Last Post 8 mar 2015, 23:08 GMT-4
Hello Carrie German
Posted: 10 years ago 8 mar 2015, 23:08 GMT-4
Hi JD,
Did you ever find a solution to this?
Thanks!
Andre
Hi JD, Did you ever find a solution to this? Thanks! Andre
