1D, ODE involving lagrange multiplier and "Failed to evaluate variable Jacobian"
I'm having some mass balance error in 2D even I use lagrange multiplier to get flux through prescribed BC. To troubleshoot this I'm trying simple 1D case. However I encounter some problems integrating lagrange multiplier over time in 1D case.
For 2D case, I can define boundary probe and used that in my ODE (global equations), however for 1D problem there are no boundary probes. I see two choices, either to define a point probe that snaps to closest point and get my p_lm/dl.rho there (flux), or to simply define model variable (flux2) for my boundary point as p_lm/dl.rho . However when I try to use either of them in ODE (with an expression for cumulative flux `cflux` like `flux-cfluxt`), I get "Failed to evaluate variable Jacobian" for mod1.p_lm if I used `flux` and for mod1.flux2 if I tried to use defined variable for my boundary point.
What would be the correct way to integrate lagrange multiplier (for prescribed point BC) over time in 1D?
0 Replies Last Post 2 giu 2011, 21:36 CEST
Hello Mikhail Titov
