7 years ago
26 lug 2018, 08:33 GMT-4
Hi Mohammad,
Did you open the "COMSOL with Livelink" program or just the "COMSOL"?
Nichal
Hi Mohammad,
Nichal
7 years ago
27 lug 2018, 10:30 GMT-4
Hi Nichal
I open the Comsol With Matlab program at the first step, then I open a specific comsol program ( e.g : prj1.mph ) at the second step .
when I write the command "mphopen" in "matlab command window" and select the comsol project( prj1.mph) , it shows :
warning : the file is read only
This is exactly what I wrote and got :
mphopen
Warning: The file "D:\comsol\projects\prj1.mph" is read-only
The COMSOL model is now accessible using the variable 'model'.
Thannks for your consideration,
Mohammad
Hi Nichal
>> mphopen
Mohammad
7 years ago
27 lug 2018, 10:57 GMT-4
I am afraid I can not help more than trying to guess because I just recently start to work with livelink...
Here are some suggestions though:
-> if you are using linux start livelink using the command: comsol server matlab
-> if you are using a computador that is not yours check the permission of the folder where you saved the file
-> try to save the file in another folder and see if it helps
-> if the .mph file is not yours check the permissions of it within COMSOL
Hope any of these help you Mohammad
Nichal
Nichal
