About Transport of diluted species
Dear Community,
I am using COMSOL Multiphisics to simulate ISFET. When I do as the tutorial tells and want to reproduce it, I got this problem.
In Add Physics, under transport of diluted species (tds), there is no Number of species text field in Dependent Variables section. So I cannot add more than one species. I found in help that not all function is available. Is it because of my software? I am using COMSOL 5.3a.
Also, in the Transport Mechanisms, only convection is available, I cannot find Migration in electric field.
Anyone knows why? Thank you so much!
Feng
4 Replies Last Post 25 lug 2018, 11:35 GMT-4
Posted: 7 years ago 25 lug 2018, 08:28 GMT-4
Updated: 6 years ago 31 gen 2019, 09:52 GMT-5
Hello Feng,
You must be referring to this tutorial: https://www.comsol.com/model/simulation-of-an-ion-sensitive-field-effect-transistor-isfet-45341
If so, please note that that tutorial requires
  1. COMSOL Multiphysics®, and
  2. Semiconductor Module, and
  3. Batteries & Fuel Cells Module, Chemical Reaction Engineering Module, Corrosion Module, Electrochemistry Module, Electrodeposition Module, or Microfluidics Module
From what you describe, it sounds like your license does not currently include any of the products in 3/ above. You can check on that by going to File > Licensed and Used Products.
Jeff Hiller
Hello Feng, You must be referring to this tutorial: https://www.comsol.com/model/simulation-of-an-ion-sensitive-field-effect-transistor-isfet-45341 If so, please note that that tutorial requires 1. COMSOL Multiphysics®, and 2. Semiconductor Module, and 3. Batteries & Fuel Cells Module, Chemical Reaction Engineering Module, Corrosion Module, Electrochemistry Module, Electrodeposition Module, or Microfluidics Module From what you describe, it sounds like your license does not currently include any of the products in 3/ above. You can check on that by going to File > Licensed and Used Products. Best, Jeff
Posted: 7 years ago 25 lug 2018, 11:28 GMT-4
Dear Jeff,
Thank you for your reply. I am still having trouble finding which are required. I want to have four species in transport of diluted species and also the transport mechanism of migration in electric field. What do I need? Do I need all those you mentioned in 3?
Thank you so much!
Best, Feng
Dear Jeff, Thank you for your reply. I am still having trouble finding which are required. I want to have four species in transport of diluted species and also the transport mechanism of migration in electric field. What do I need? Do I need all those you mentioned in 3? Thank you so much! Best, Feng
Posted: 7 years ago 25 lug 2018, 11:34 GMT-4
From the 3rd bullet, you need any one of those modules. I should have typed
Batteries & Fuel Cells Module, or Chemical Reaction Engineering Module, or Corrosion Module, or Electrochemistry Module, or Electrodeposition Module, or Microfluidics Module
Jeff Hiller
From the 3rd bullet, you need any one of those modules. I should have typed Batteries & Fuel Cells Module, or Chemical Reaction Engineering Module, or Corrosion Module, or Electrochemistry Module, or Electrodeposition Module, or Microfluidics Module Best, Jeff
Posted: 7 years ago 25 lug 2018, 11:35 GMT-4
Dear Jeff,
Thank you so much! That really helps!
Best, Feng
Dear Jeff, Thank you so much! That really helps! Best, Feng
